Leidingnippels (Amerikaanse AN-maten)
Locked
Post by BigBlockMopar » Tue Nov 16, 2004 6:56 pm
OK, so you're ready to order fittings for that new fuel system you just got. Now there's only one thing: What's a -6 or -8 AN fitting?
"AN" (Army Navy) Sizes were established by the aerospace industry. The measurements represent the O.D. (outside diameter) of rigid metal tubes. Basically, dash sizes are the numerators of fractions with a denominator of 16. *
EXAMPLE:
-6 is equal to 6/16 in. which is equal to 3/8 in.
-8 is equal to 8/16 in. which is equal to 1/2 in.
In the examples above, a -6 AN fitting would work with a pipe that has a 3/8 in. O.D. A -8 AN fitting would be used with 1/2 in. O.D. pipe.
Here's a simple chart, just in case you don't want to do the math.
* -02 AN is equal to 1/8 in.
* -03 AN is equal to 3/16 in.
* -04 AN is equal to 1/4 in.
* -05 AN is equal to 5/16 in.
* -06 AN is equal to 3/8 in.
* -08 AN is equal to 1/2 in.
* -10 AN is equal to 5/8 in.
* -12 AN is equal to 3/4 in.
* -14 AN is equal to 7/8 in.
* -16 AN is equal to 1 in.
* -20 AN is equal to 1 1/4 in.
* -24 AN is equal to 1 1/2 in.
* -32 AN is equal to 2 in.
The most commonly used fittings are adapters. These adapters connect an AN fitting to a pipe thread fitting. Most fuel pumps, regulators, and canister type fuel filters, come with pipe thread inlet/outlet ports. In order to use braided line, the ports need to be changed to a AN type of fitting. This is when a "pipe to AN adapter" is needed.
The most popular sizes used in fuel systems are the -6 and the -8 AN, although some high performance fuel pumps and regulators require a -10 AN fitting.
* - Aanvullende Tech-info van Twin_Turbo:
De AN maten zijn idd 16'en van Inches, dus bijv een 6 an leiding is 3/8", echter dit is niet de binnendiameter van de leiding.
De binnendiameter van AN leidingen is gebaseerd op de binnendiameter van gaspijp met de corresponderende buitendiameter, dus een 3/8 (6an) leiding heeft dezelfde binnendiameter als een gaspijp met een 3/8"buitendiameter.
Oh ja in Europa heet AN ook wel JIC.
Locked
