* @license GNU General Public License, version 2 (GPL-2.0) * * For full copyright and license information, please see * the docs/CREDITS.txt file. * */ /** * @ignore */ define('IN_PHPBB', true); $phpbb_root_path = (defined('PHPBB_ROOT_PATH')) ? PHPBB_ROOT_PATH : './'; $phpEx = substr(strrchr(__FILE__, '.'), 1); include($phpbb_root_path . 'common.' . $phpEx); include($phpbb_root_path . 'includes/functions_display.' . $phpEx); include($phpbb_root_path . 'includes/bbcode.' . $phpEx); include($phpbb_root_path . 'includes/functions_user.' . $phpEx); // Start session management $user->session_begin(); $auth->acl($user->data); // Initial var setup $forum_id = $request->variable('f', 0); $topic_id = $request->variable('t', 0); $post_id = $request->variable('p', 0); $voted_id = $request->variable('vote_id', array('' => 0)); $voted_id = (count($voted_id) > 1) ? array_unique($voted_id) : $voted_id; $start = $request->variable('start', 0); $view = $request->variable('view', ''); $default_sort_days = (!empty($user->data['user_post_show_days'])) ? $user->data['user_post_show_days'] : 0; $default_sort_key = (!empty($user->data['user_post_sortby_type'])) ? $user->data['user_post_sortby_type'] : 't'; $default_sort_dir = (!empty($user->data['user_post_sortby_dir'])) ? $user->data['user_post_sortby_dir'] : 'a'; $sort_days = $request->variable('st', $default_sort_days); $sort_key = $request->variable('sk', $default_sort_key); $sort_dir = $request->variable('sd', $default_sort_dir); $update = $request->variable('update', false); /* @var $pagination \phpbb\pagination */ $pagination = $phpbb_container->get('pagination'); $s_can_vote = false; /** * @todo normalize? */ $hilit_words = $request->variable('hilit', '', true); // Do we have a topic or post id? if (!$topic_id && !$post_id) { trigger_error('NO_TOPIC'); } /* @var $phpbb_content_visibility \phpbb\content_visibility */ $phpbb_content_visibility = $phpbb_container->get('content.visibility'); // Find topic id if user requested a newer or older topic if ($view && !$post_id) { if (!$forum_id) { $sql = 'SELECT forum_id FROM ' . TOPICS_TABLE . " WHERE topic_id = $topic_id"; $result = $db->sql_query($sql); $forum_id = (int) $db->sql_fetchfield('forum_id'); $db->sql_freeresult($result); if (!$forum_id) { trigger_error('NO_TOPIC'); } } if ($view == 'unread') { // Get topic tracking info $topic_tracking_info = get_complete_topic_tracking($forum_id, $topic_id); $topic_last_read = (isset($topic_tracking_info[$topic_id])) ? $topic_tracking_info[$topic_id] : 0; $sql = 'SELECT post_id, topic_id, forum_id FROM ' . POSTS_TABLE . " WHERE topic_id = $topic_id AND " . $phpbb_content_visibility->get_visibility_sql('post', $forum_id) . " AND post_time > $topic_last_read AND forum_id = $forum_id ORDER BY post_time ASC, post_id ASC"; $result = $db->sql_query_limit($sql, 1); $row = $db->sql_fetchrow($result); $db->sql_freeresult($result); if (!$row) { $sql = 'SELECT topic_last_post_id as post_id, topic_id, forum_id FROM ' . TOPICS_TABLE . ' WHERE topic_id = ' . $topic_id; $result = $db->sql_query($sql); $row = $db->sql_fetchrow($result); $db->sql_freeresult($result); } if (!$row) { // Setup user environment so we can process lang string $user->setup('viewtopic'); trigger_error('NO_TOPIC'); } $post_id = $row['post_id']; $topic_id = $row['topic_id']; } else if ($view == 'next' || $view == 'previous') { $sql_condition = ($view == 'next') ? '>' : '<'; $sql_ordering = ($view == 'next') ? 'ASC' : 'DESC'; $sql = 'SELECT forum_id, topic_last_post_time FROM ' . TOPICS_TABLE . ' WHERE topic_id = ' . $topic_id; $result = $db->sql_query($sql); $row = $db->sql_fetchrow($result); $db->sql_freeresult($result); if (!$row) { $user->setup('viewtopic'); // OK, the topic doesn't exist. This error message is not helpful, but technically correct. trigger_error(($view == 'next') ? 'NO_NEWER_TOPICS' : 'NO_OLDER_TOPICS'); } else { $sql = 'SELECT topic_id, forum_id FROM ' . TOPICS_TABLE . ' WHERE forum_id = ' . $row['forum_id'] . " AND topic_moved_id = 0 AND topic_last_post_time $sql_condition {$row['topic_last_post_time']} AND " . $phpbb_content_visibility->get_visibility_sql('topic', $row['forum_id']) . " ORDER BY topic_last_post_time $sql_ordering, topic_last_post_id $sql_ordering"; $result = $db->sql_query_limit($sql, 1); $row = $db->sql_fetchrow($result); $db->sql_freeresult($result); if (!$row) { $sql = 'SELECT forum_style FROM ' . FORUMS_TABLE . " WHERE forum_id = $forum_id"; $result = $db->sql_query($sql); $forum_style = (int) $db->sql_fetchfield('forum_style'); $db->sql_freeresult($result); $user->setup('viewtopic', $forum_style); trigger_error(($view == 'next') ? 'NO_NEWER_TOPICS' : 'NO_OLDER_TOPICS'); } else { $topic_id = $row['topic_id']; $forum_id = $row['forum_id']; } } } if (isset($row) && $row['forum_id']) { $forum_id = $row['forum_id']; } } // This rather complex gaggle of code handles querying for topics but // also allows for direct linking to a post (and the calculation of which // page the post is on and the correct display of viewtopic) $sql_array = array( 'SELECT' => 't.*, f.*', 'FROM' => array(FORUMS_TABLE => 'f'), ); // The FROM-Order is quite important here, else t.* columns can not be correctly bound. if ($post_id) { $sql_array['SELECT'] .= ', p.post_visibility, p.post_time, p.post_id'; $sql_array['FROM'][POSTS_TABLE] = 'p'; } // Topics table need to be the last in the chain $sql_array['FROM'][TOPICS_TABLE] = 't'; if ($user->data['is_registered']) { $sql_array['SELECT'] .= ', tw.notify_status'; $sql_array['LEFT_JOIN'] = array(); $sql_array['LEFT_JOIN'][] = array( 'FROM' => array(TOPICS_WATCH_TABLE => 'tw'), 'ON' => 'tw.user_id = ' . $user->data['user_id'] . ' AND t.topic_id = tw.topic_id' ); if ($config['allow_bookmarks']) { $sql_array['SELECT'] .= ', bm.topic_id as bookmarked'; $sql_array['LEFT_JOIN'][] = array( 'FROM' => array(BOOKMARKS_TABLE => 'bm'), 'ON' => 'bm.user_id = ' . $user->data['user_id'] . ' AND t.topic_id = bm.topic_id' ); } if ($config['load_db_lastread']) { $sql_array['SELECT'] .= ', tt.mark_time, ft.mark_time as forum_mark_time'; $sql_array['LEFT_JOIN'][] = array( 'FROM' => array(TOPICS_TRACK_TABLE => 'tt'), 'ON' => 'tt.user_id = ' . $user->data['user_id'] . ' AND t.topic_id = tt.topic_id' ); $sql_array['LEFT_JOIN'][] = array( 'FROM' => array(FORUMS_TRACK_TABLE => 'ft'), 'ON' => 'ft.user_id = ' . $user->data['user_id'] . ' AND t.forum_id = ft.forum_id' ); } } if (!$post_id) { $sql_array['WHERE'] = "t.topic_id = $topic_id"; } else { $sql_array['WHERE'] = "p.post_id = $post_id AND t.topic_id = p.topic_id"; } $sql_array['WHERE'] .= ' AND f.forum_id = t.forum_id'; $sql = $db->sql_build_query('SELECT', $sql_array); $result = $db->sql_query($sql); $topic_data = $db->sql_fetchrow($result); $db->sql_freeresult($result); // link to unapproved post or incorrect link if (!$topic_data) { // If post_id was submitted, we try at least to display the topic as a last resort... if ($post_id && $topic_id) { redirect(append_sid("{$phpbb_root_path}viewtopic.$phpEx", "t=$topic_id" . (($forum_id) ? "&f=$forum_id" : ''))); } trigger_error('NO_TOPIC'); } $forum_id = (int) $topic_data['forum_id']; /** * Modify the forum ID to handle the correct display of viewtopic if needed * * @event core.viewtopic_modify_forum_id * @var string forum_id forum ID * @var array topic_data array of topic's data * @since 3.2.5-RC1 */ $vars = array( 'forum_id', 'topic_data', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_modify_forum_id', compact($vars))); // If the request is missing the f parameter, the forum id in the user session data is 0 at the moment. // Let's fix that now so that the user can't hide from the forum's Who Is Online list. $user->page['forum'] = $forum_id; // Now we know the forum_id and can check the permissions if (!$phpbb_content_visibility->is_visible('topic', $forum_id, $topic_data)) { trigger_error('NO_TOPIC'); } // This is for determining where we are (page) if ($post_id) { // are we where we are supposed to be? if (($topic_data['post_visibility'] == ITEM_UNAPPROVED || $topic_data['post_visibility'] == ITEM_REAPPROVE) && !$auth->acl_get('m_approve', $topic_data['forum_id'])) { // If post_id was submitted, we try at least to display the topic as a last resort... if ($topic_id) { redirect(append_sid("{$phpbb_root_path}viewtopic.$phpEx", "t=$topic_id" . (($forum_id) ? "&f=$forum_id" : ''))); } trigger_error('NO_TOPIC'); } if ($post_id == $topic_data['topic_first_post_id'] || $post_id == $topic_data['topic_last_post_id']) { $check_sort = ($post_id == $topic_data['topic_first_post_id']) ? 'd' : 'a'; if ($sort_dir == $check_sort) { $topic_data['prev_posts'] = $phpbb_content_visibility->get_count('topic_posts', $topic_data, $forum_id) - 1; } else { $topic_data['prev_posts'] = 0; } } else { $sql = 'SELECT COUNT(p.post_id) AS prev_posts FROM ' . POSTS_TABLE . " p WHERE p.topic_id = {$topic_data['topic_id']} AND " . $phpbb_content_visibility->get_visibility_sql('post', $forum_id, 'p.'); if ($sort_dir == 'd') { $sql .= " AND (p.post_time > {$topic_data['post_time']} OR (p.post_time = {$topic_data['post_time']} AND p.post_id >= {$topic_data['post_id']}))"; } else { $sql .= " AND (p.post_time < {$topic_data['post_time']} OR (p.post_time = {$topic_data['post_time']} AND p.post_id <= {$topic_data['post_id']}))"; } $result = $db->sql_query($sql); $row = $db->sql_fetchrow($result); $db->sql_freeresult($result); $topic_data['prev_posts'] = $row['prev_posts'] - 1; } } $topic_id = (int) $topic_data['topic_id']; $topic_replies = $phpbb_content_visibility->get_count('topic_posts', $topic_data, $forum_id) - 1; // Check sticky/announcement/global time limit if (($topic_data['topic_type'] != POST_NORMAL) && $topic_data['topic_time_limit'] && ($topic_data['topic_time'] + $topic_data['topic_time_limit']) < time()) { $sql = 'UPDATE ' . TOPICS_TABLE . ' SET topic_type = ' . POST_NORMAL . ', topic_time_limit = 0 WHERE topic_id = ' . $topic_id; $db->sql_query($sql); $topic_data['topic_type'] = POST_NORMAL; $topic_data['topic_time_limit'] = 0; } // Setup look and feel $user->setup('viewtopic', $topic_data['forum_style']); if ($view == 'print' && !$auth->acl_get('f_print', $forum_id)) { send_status_line(403, 'Forbidden'); trigger_error('NO_AUTH_PRINT_TOPIC'); } $overrides_f_read_check = false; $overrides_forum_password_check = false; $topic_tracking_info = isset($topic_tracking_info) ? $topic_tracking_info : null; /** * Event to apply extra permissions and to override original phpBB's f_read permission and forum password check * on viewtopic access * * @event core.viewtopic_before_f_read_check * @var int forum_id The forum id from where the topic belongs * @var int topic_id The id of the topic the user tries to access * @var int post_id The id of the post the user tries to start viewing at. * It may be 0 for none given. * @var array topic_data All the information from the topic and forum tables for this topic * It includes posts information if post_id is not 0 * @var bool overrides_f_read_check Set true to remove f_read check afterwards * @var bool overrides_forum_password_check Set true to remove forum_password check afterwards * @var array topic_tracking_info Information upon calling get_topic_tracking() * Set it to NULL to allow auto-filling later. * Set it to an array to override original data. * @since 3.1.3-RC1 */ $vars = array( 'forum_id', 'topic_id', 'post_id', 'topic_data', 'overrides_f_read_check', 'overrides_forum_password_check', 'topic_tracking_info', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_before_f_read_check', compact($vars))); // Start auth check if (!$overrides_f_read_check && !$auth->acl_get('f_read', $forum_id)) { if ($user->data['user_id'] != ANONYMOUS) { send_status_line(403, 'Forbidden'); trigger_error('SORRY_AUTH_READ'); } login_box('', $user->lang['LOGIN_VIEWFORUM']); } // Forum is passworded ... check whether access has been granted to this // user this session, if not show login box if (!$overrides_forum_password_check && $topic_data['forum_password']) { login_forum_box($topic_data); } // Redirect to login upon emailed notification links if user is not logged in. if (isset($_GET['e']) && $user->data['user_id'] == ANONYMOUS) { login_box(build_url('e') . '#unread', $user->lang['LOGIN_NOTIFY_TOPIC']); } // What is start equal to? if ($post_id) { $start = floor(($topic_data['prev_posts']) / $config['posts_per_page']) * $config['posts_per_page']; } // Get topic tracking info if (!isset($topic_tracking_info)) { $topic_tracking_info = array(); // Get topic tracking info if ($config['load_db_lastread'] && $user->data['is_registered']) { $tmp_topic_data = array($topic_id => $topic_data); $topic_tracking_info = get_topic_tracking($forum_id, $topic_id, $tmp_topic_data, array($forum_id => $topic_data['forum_mark_time'])); unset($tmp_topic_data); } else if ($config['load_anon_lastread'] || $user->data['is_registered']) { $topic_tracking_info = get_complete_topic_tracking($forum_id, $topic_id); } } // Post ordering options $limit_days = array(0 => $user->lang['ALL_POSTS'], 1 => $user->lang['1_DAY'], 7 => $user->lang['7_DAYS'], 14 => $user->lang['2_WEEKS'], 30 => $user->lang['1_MONTH'], 90 => $user->lang['3_MONTHS'], 180 => $user->lang['6_MONTHS'], 365 => $user->lang['1_YEAR']); $sort_by_text = array('a' => $user->lang['AUTHOR'], 't' => $user->lang['POST_TIME'], 's' => $user->lang['SUBJECT']); $sort_by_sql = array('a' => array('u.username_clean', 'p.post_id'), 't' => array('p.post_time', 'p.post_id'), 's' => array('p.post_subject', 'p.post_id')); $join_user_sql = array('a' => true, 't' => false, 's' => false); $s_limit_days = $s_sort_key = $s_sort_dir = $u_sort_param = ''; /** * Event to add new sorting options * * @event core.viewtopic_gen_sort_selects_before * @var array limit_days Limit results by time * @var array sort_by_text Language strings for sorting options * @var array sort_by_sql SQL conditions for sorting options * @var array join_user_sql SQL joins required for sorting options * @var int sort_days User selected sort days * @var string sort_key User selected sort key * @var string sort_dir User selected sort direction * @var string s_limit_days Initial value of limit days selectbox * @var string s_sort_key Initial value of sort key selectbox * @var string s_sort_dir Initial value of sort direction selectbox * @var string u_sort_param Initial value of sorting form action * @since 3.2.8-RC1 */ $vars = array( 'limit_days', 'sort_by_text', 'sort_by_sql', 'join_user_sql', 'sort_days', 'sort_key', 'sort_dir', 's_limit_days', 's_sort_key', 's_sort_dir', 'u_sort_param', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_gen_sort_selects_before', compact($vars))); gen_sort_selects($limit_days, $sort_by_text, $sort_days, $sort_key, $sort_dir, $s_limit_days, $s_sort_key, $s_sort_dir, $u_sort_param, $default_sort_days, $default_sort_key, $default_sort_dir); // Obtain correct post count and ordering SQL if user has // requested anything different if ($sort_days) { $min_post_time = time() - ($sort_days * 86400); $sql = 'SELECT COUNT(post_id) AS num_posts FROM ' . POSTS_TABLE . " WHERE topic_id = $topic_id AND post_time >= $min_post_time AND " . $phpbb_content_visibility->get_visibility_sql('post', $forum_id); $result = $db->sql_query($sql); $total_posts = (int) $db->sql_fetchfield('num_posts'); $db->sql_freeresult($result); $limit_posts_time = "AND p.post_time >= $min_post_time "; if (isset($_POST['sort'])) { $start = 0; } } else { $total_posts = $topic_replies + 1; $limit_posts_time = ''; } // Was a highlight request part of the URI? $highlight_match = $highlight = ''; if ($hilit_words) { $highlight_match = phpbb_clean_search_string($hilit_words); $highlight = urlencode($highlight_match); $highlight_match = str_replace('\*', '\w+?', preg_quote($highlight_match, '#')); $highlight_match = preg_replace('#(?<=^|\s)\\\\w\*\?(?=\s|$)#', '\w+?', $highlight_match); $highlight_match = str_replace(' ', '|', $highlight_match); } // Make sure $start is set to the last page if it exceeds the amount $start = $pagination->validate_start($start, $config['posts_per_page'], $total_posts); // General Viewtopic URL for return links $viewtopic_url = append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&t=$topic_id" . (($start == 0) ? '' : "&start=$start") . ((strlen($u_sort_param)) ? "&$u_sort_param" : '') . (($highlight_match) ? "&hilit=$highlight" : '')); // Are we watching this topic? $s_watching_topic = array( 'link' => '', 'link_toggle' => '', 'title' => '', 'title_toggle' => '', 'is_watching' => false, ); if ($config['allow_topic_notify']) { $notify_status = (isset($topic_data['notify_status'])) ? $topic_data['notify_status'] : null; watch_topic_forum('topic', $s_watching_topic, $user->data['user_id'], $forum_id, $topic_id, $notify_status, $start, $topic_data['topic_title']); // Reset forum notification if forum notify is set if ($config['allow_forum_notify'] && $auth->acl_get('f_subscribe', $forum_id)) { $s_watching_forum = $s_watching_topic; watch_topic_forum('forum', $s_watching_forum, $user->data['user_id'], $forum_id, 0); } } /** * Event to modify highlight. * * @event core.viewtopic_highlight_modify * @var string highlight String to be highlighted * @var string highlight_match Highlight string to be used in preg_replace * @var array topic_data Topic data * @var int start Pagination start * @var int total_posts Number of posts * @var string viewtopic_url Current viewtopic URL * @since 3.1.11-RC1 */ $vars = array( 'highlight', 'highlight_match', 'topic_data', 'start', 'total_posts', 'viewtopic_url', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_highlight_modify', compact($vars))); // Bookmarks if ($config['allow_bookmarks'] && $user->data['is_registered'] && $request->variable('bookmark', 0)) { if (check_link_hash($request->variable('hash', ''), "topic_$topic_id")) { if (!$topic_data['bookmarked']) { $sql = 'INSERT INTO ' . BOOKMARKS_TABLE . ' ' . $db->sql_build_array('INSERT', array( 'user_id' => $user->data['user_id'], 'topic_id' => $topic_id, )); $db->sql_query($sql); } else { $sql = 'DELETE FROM ' . BOOKMARKS_TABLE . " WHERE user_id = {$user->data['user_id']} AND topic_id = $topic_id"; $db->sql_query($sql); } $message = (($topic_data['bookmarked']) ? $user->lang['BOOKMARK_REMOVED'] : $user->lang['BOOKMARK_ADDED']); if (!$request->is_ajax()) { $message .= '
' . $user->lang('RETURN_TOPIC', '', ''); } } else { $message = $user->lang['BOOKMARK_ERR']; if (!$request->is_ajax()) { $message .= '
' . $user->lang('RETURN_TOPIC', '', ''); } } meta_refresh(3, $viewtopic_url); trigger_error($message); } // Grab ranks $ranks = $cache->obtain_ranks(); // Grab icons $icons = $cache->obtain_icons(); // Grab extensions $extensions = array(); if ($topic_data['topic_attachment']) { $extensions = $cache->obtain_attach_extensions($forum_id); } // Forum rules listing $s_forum_rules = ''; gen_forum_auth_level('topic', $forum_id, $topic_data['forum_status']); // Quick mod tools $allow_change_type = ($auth->acl_get('m_', $forum_id) || ($user->data['is_registered'] && $user->data['user_id'] == $topic_data['topic_poster'])) ? true : false; $s_quickmod_action = append_sid( "{$phpbb_root_path}mcp.$phpEx", array( 'f' => $forum_id, 't' => $topic_id, 'start' => $start, 'quickmod' => 1, 'redirect' => urlencode(str_replace('&', '&', $viewtopic_url)), ), true, $user->session_id ); $quickmod_array = array( // 'key' => array('LANG_KEY', $userHasPermissions), 'lock' => array('LOCK_TOPIC', ($topic_data['topic_status'] == ITEM_UNLOCKED) && ($auth->acl_get('m_lock', $forum_id) || ($auth->acl_get('f_user_lock', $forum_id) && $user->data['is_registered'] && $user->data['user_id'] == $topic_data['topic_poster']))), 'unlock' => array('UNLOCK_TOPIC', ($topic_data['topic_status'] != ITEM_UNLOCKED) && ($auth->acl_get('m_lock', $forum_id))), 'delete_topic' => array('DELETE_TOPIC', ($auth->acl_get('m_delete', $forum_id) || (($topic_data['topic_visibility'] != ITEM_DELETED) && $auth->acl_get('m_softdelete', $forum_id)))), 'restore_topic' => array('RESTORE_TOPIC', (($topic_data['topic_visibility'] == ITEM_DELETED) && $auth->acl_get('m_approve', $forum_id))), 'move' => array('MOVE_TOPIC', $auth->acl_get('m_move', $forum_id) && $topic_data['topic_status'] != ITEM_MOVED), 'split' => array('SPLIT_TOPIC', $auth->acl_get('m_split', $forum_id)), 'merge' => array('MERGE_POSTS', $auth->acl_get('m_merge', $forum_id)), 'merge_topic' => array('MERGE_TOPIC', $auth->acl_get('m_merge', $forum_id)), 'fork' => array('FORK_TOPIC', $auth->acl_get('m_move', $forum_id)), 'make_normal' => array('MAKE_NORMAL', ($allow_change_type && $auth->acl_gets('f_sticky', 'f_announce', 'f_announce_global', $forum_id) && $topic_data['topic_type'] != POST_NORMAL)), 'make_sticky' => array('MAKE_STICKY', ($allow_change_type && $auth->acl_get('f_sticky', $forum_id) && $topic_data['topic_type'] != POST_STICKY)), 'make_announce' => array('MAKE_ANNOUNCE', ($allow_change_type && $auth->acl_get('f_announce', $forum_id) && $topic_data['topic_type'] != POST_ANNOUNCE)), 'make_global' => array('MAKE_GLOBAL', ($allow_change_type && $auth->acl_get('f_announce_global', $forum_id) && $topic_data['topic_type'] != POST_GLOBAL)), 'topic_logs' => array('VIEW_TOPIC_LOGS', $auth->acl_get('m_', $forum_id)), ); /** * Event to modify data in the quickmod_array before it gets sent to the * phpbb_add_quickmod_option function. * * @event core.viewtopic_add_quickmod_option_before * @var int forum_id Forum ID * @var int post_id Post ID * @var array quickmod_array Array with quick moderation options data * @var array topic_data Array with topic data * @var int topic_id Topic ID * @var array topic_tracking_info Array with topic tracking data * @var string viewtopic_url URL to the topic page * @var bool allow_change_type Topic change permissions check * @since 3.1.9-RC1 */ $vars = array( 'forum_id', 'post_id', 'quickmod_array', 'topic_data', 'topic_id', 'topic_tracking_info', 'viewtopic_url', 'allow_change_type', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_add_quickmod_option_before', compact($vars))); foreach ($quickmod_array as $option => $qm_ary) { if (!empty($qm_ary[1])) { phpbb_add_quickmod_option($s_quickmod_action, $option, $qm_ary[0]); } } // Navigation links generate_forum_nav($topic_data); // Forum Rules generate_forum_rules($topic_data); // Moderators $forum_moderators = array(); if ($config['load_moderators']) { get_moderators($forum_moderators, $forum_id); } // This is only used for print view so ... $server_path = (!$view) ? $phpbb_root_path : generate_board_url() . '/'; // Replace naughty words in title $topic_data['topic_title'] = censor_text($topic_data['topic_title']); $s_search_hidden_fields = array( 't' => $topic_id, 'sf' => 'msgonly', ); if ($_SID) { $s_search_hidden_fields['sid'] = $_SID; } if (!empty($_EXTRA_URL)) { foreach ($_EXTRA_URL as $url_param) { $url_param = explode('=', $url_param, 2); $s_search_hidden_fields[$url_param[0]] = $url_param[1]; } } // If we've got a hightlight set pass it on to pagination. $base_url = append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&t=$topic_id" . ((strlen($u_sort_param)) ? "&$u_sort_param" : '') . (($highlight_match) ? "&hilit=$highlight" : '')); /** * Event to modify data before template variables are being assigned * * @event core.viewtopic_assign_template_vars_before * @var string base_url URL to be passed to generate pagination * @var int forum_id Forum ID * @var int post_id Post ID * @var array quickmod_array Array with quick moderation options data * @var int start Pagination information * @var array topic_data Array with topic data * @var int topic_id Topic ID * @var array topic_tracking_info Array with topic tracking data * @var int total_posts Topic total posts count * @var string viewtopic_url URL to the topic page * @since 3.1.0-RC4 * @changed 3.1.2-RC1 Added viewtopic_url */ $vars = array( 'base_url', 'forum_id', 'post_id', 'quickmod_array', 'start', 'topic_data', 'topic_id', 'topic_tracking_info', 'total_posts', 'viewtopic_url', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_assign_template_vars_before', compact($vars))); $pagination->generate_template_pagination($base_url, 'pagination', 'start', $total_posts, $config['posts_per_page'], $start); // Send vars to template $template->assign_vars(array( 'FORUM_ID' => $forum_id, 'FORUM_NAME' => $topic_data['forum_name'], 'FORUM_DESC' => generate_text_for_display($topic_data['forum_desc'], $topic_data['forum_desc_uid'], $topic_data['forum_desc_bitfield'], $topic_data['forum_desc_options']), 'TOPIC_ID' => $topic_id, 'TOPIC_TITLE' => $topic_data['topic_title'], 'TOPIC_POSTER' => $topic_data['topic_poster'], 'TOPIC_AUTHOR_FULL' => get_username_string('full', $topic_data['topic_poster'], $topic_data['topic_first_poster_name'], $topic_data['topic_first_poster_colour']), 'TOPIC_AUTHOR_COLOUR' => get_username_string('colour', $topic_data['topic_poster'], $topic_data['topic_first_poster_name'], $topic_data['topic_first_poster_colour']), 'TOPIC_AUTHOR' => get_username_string('username', $topic_data['topic_poster'], $topic_data['topic_first_poster_name'], $topic_data['topic_first_poster_colour']), 'TOTAL_POSTS' => $user->lang('VIEW_TOPIC_POSTS', (int) $total_posts), 'U_MCP' => ($auth->acl_get('m_', $forum_id)) ? append_sid("{$phpbb_root_path}mcp.$phpEx", "i=main&mode=topic_view&f=$forum_id&t=$topic_id" . (($start == 0) ? '' : "&start=$start") . ((strlen($u_sort_param)) ? "&$u_sort_param" : ''), true, $user->session_id) : '', 'MODERATORS' => (isset($forum_moderators[$forum_id]) && count($forum_moderators[$forum_id])) ? implode($user->lang['COMMA_SEPARATOR'], $forum_moderators[$forum_id]) : '', 'POST_IMG' => ($topic_data['forum_status'] == ITEM_LOCKED) ? $user->img('button_topic_locked', 'FORUM_LOCKED') : $user->img('button_topic_new', 'POST_NEW_TOPIC'), 'QUOTE_IMG' => $user->img('icon_post_quote', 'REPLY_WITH_QUOTE'), 'REPLY_IMG' => ($topic_data['forum_status'] == ITEM_LOCKED || $topic_data['topic_status'] == ITEM_LOCKED) ? $user->img('button_topic_locked', 'TOPIC_LOCKED') : $user->img('button_topic_reply', 'REPLY_TO_TOPIC'), 'EDIT_IMG' => $user->img('icon_post_edit', 'EDIT_POST'), 'DELETE_IMG' => $user->img('icon_post_delete', 'DELETE_POST'), 'DELETED_IMG' => $user->img('icon_topic_deleted', 'POST_DELETED_RESTORE'), 'INFO_IMG' => $user->img('icon_post_info', 'VIEW_INFO'), 'PROFILE_IMG' => $user->img('icon_user_profile', 'READ_PROFILE'), 'SEARCH_IMG' => $user->img('icon_user_search', 'SEARCH_USER_POSTS'), 'PM_IMG' => $user->img('icon_contact_pm', 'SEND_PRIVATE_MESSAGE'), 'EMAIL_IMG' => $user->img('icon_contact_email', 'SEND_EMAIL'), 'JABBER_IMG' => $user->img('icon_contact_jabber', 'JABBER') , 'REPORT_IMG' => $user->img('icon_post_report', 'REPORT_POST'), 'REPORTED_IMG' => $user->img('icon_topic_reported', 'POST_REPORTED'), 'UNAPPROVED_IMG' => $user->img('icon_topic_unapproved', 'POST_UNAPPROVED'), 'WARN_IMG' => $user->img('icon_user_warn', 'WARN_USER'), 'S_IS_LOCKED' => ($topic_data['topic_status'] == ITEM_UNLOCKED && $topic_data['forum_status'] == ITEM_UNLOCKED) ? false : true, 'S_SELECT_SORT_DIR' => $s_sort_dir, 'S_SELECT_SORT_KEY' => $s_sort_key, 'S_SELECT_SORT_DAYS' => $s_limit_days, 'S_SINGLE_MODERATOR' => (!empty($forum_moderators[$forum_id]) && count($forum_moderators[$forum_id]) > 1) ? false : true, 'S_TOPIC_ACTION' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&t=$topic_id" . (($start == 0) ? '' : "&start=$start")), 'S_MOD_ACTION' => $s_quickmod_action, 'L_RETURN_TO_FORUM' => $user->lang('RETURN_TO', $topic_data['forum_name']), 'S_VIEWTOPIC' => true, 'S_UNREAD_VIEW' => $view == 'unread', 'S_DISPLAY_SEARCHBOX' => ($auth->acl_get('u_search') && $auth->acl_get('f_search', $forum_id) && $config['load_search']) ? true : false, 'S_SEARCHBOX_ACTION' => append_sid("{$phpbb_root_path}search.$phpEx"), 'S_SEARCH_LOCAL_HIDDEN_FIELDS' => build_hidden_fields($s_search_hidden_fields), 'S_DISPLAY_POST_INFO' => ($topic_data['forum_type'] == FORUM_POST && ($auth->acl_get('f_post', $forum_id) || $user->data['user_id'] == ANONYMOUS)) ? true : false, 'S_DISPLAY_REPLY_INFO' => ($topic_data['forum_type'] == FORUM_POST && ($auth->acl_get('f_reply', $forum_id) || $user->data['user_id'] == ANONYMOUS)) ? true : false, 'S_ENABLE_FEEDS_TOPIC' => ($config['feed_topic'] && !phpbb_optionget(FORUM_OPTION_FEED_EXCLUDE, $topic_data['forum_options'])) ? true : false, 'U_TOPIC' => "{$server_path}viewtopic.$phpEx?f=$forum_id&t=$topic_id", 'U_FORUM' => $server_path, 'U_VIEW_TOPIC' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&t=$topic_id" . (($start == 0) ? '' : "&start=$start") . (strlen($u_sort_param) ? "&$u_sort_param" : '')), 'U_CANONICAL' => generate_board_url() . '/' . append_sid("viewtopic.$phpEx", "t=$topic_id" . (($start) ? "&start=$start" : ''), true, ''), 'U_VIEW_FORUM' => append_sid("{$phpbb_root_path}viewforum.$phpEx", 'f=' . $forum_id), 'U_VIEW_OLDER_TOPIC' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&t=$topic_id&view=previous"), 'U_VIEW_NEWER_TOPIC' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&t=$topic_id&view=next"), 'U_PRINT_TOPIC' => ($auth->acl_get('f_print', $forum_id)) ? $viewtopic_url . '&view=print' : '', 'U_EMAIL_TOPIC' => ($auth->acl_get('f_email', $forum_id) && $config['email_enable']) ? append_sid("{$phpbb_root_path}memberlist.$phpEx", "mode=email&t=$topic_id") : '', 'U_WATCH_TOPIC' => $s_watching_topic['link'], 'U_WATCH_TOPIC_TOGGLE' => $s_watching_topic['link_toggle'], 'S_WATCH_TOPIC_TITLE' => $s_watching_topic['title'], 'S_WATCH_TOPIC_TOGGLE' => $s_watching_topic['title_toggle'], 'S_WATCHING_TOPIC' => $s_watching_topic['is_watching'], 'U_BOOKMARK_TOPIC' => ($user->data['is_registered'] && $config['allow_bookmarks']) ? $viewtopic_url . '&bookmark=1&hash=' . generate_link_hash("topic_$topic_id") : '', 'S_BOOKMARK_TOPIC' => ($user->data['is_registered'] && $config['allow_bookmarks'] && $topic_data['bookmarked']) ? $user->lang['BOOKMARK_TOPIC_REMOVE'] : $user->lang['BOOKMARK_TOPIC'], 'S_BOOKMARK_TOGGLE' => (!$user->data['is_registered'] || !$config['allow_bookmarks'] || !$topic_data['bookmarked']) ? $user->lang['BOOKMARK_TOPIC_REMOVE'] : $user->lang['BOOKMARK_TOPIC'], 'S_BOOKMARKED_TOPIC' => ($user->data['is_registered'] && $config['allow_bookmarks'] && $topic_data['bookmarked']) ? true : false, 'U_POST_NEW_TOPIC' => ($auth->acl_get('f_post', $forum_id) || $user->data['user_id'] == ANONYMOUS) ? append_sid("{$phpbb_root_path}posting.$phpEx", "mode=post&f=$forum_id") : '', 'U_POST_REPLY_TOPIC' => ($auth->acl_get('f_reply', $forum_id) || $user->data['user_id'] == ANONYMOUS) ? append_sid("{$phpbb_root_path}posting.$phpEx", "mode=reply&f=$forum_id&t=$topic_id") : '', 'U_BUMP_TOPIC' => (bump_topic_allowed($forum_id, $topic_data['topic_bumped'], $topic_data['topic_last_post_time'], $topic_data['topic_poster'], $topic_data['topic_last_poster_id'])) ? append_sid("{$phpbb_root_path}posting.$phpEx", "mode=bump&f=$forum_id&t=$topic_id&hash=" . generate_link_hash("topic_$topic_id")) : '') ); // Does this topic contain a poll? if (!empty($topic_data['poll_start'])) { $sql = 'SELECT o.*, p.bbcode_bitfield, p.bbcode_uid FROM ' . POLL_OPTIONS_TABLE . ' o, ' . POSTS_TABLE . " p WHERE o.topic_id = $topic_id AND p.post_id = {$topic_data['topic_first_post_id']} AND p.topic_id = o.topic_id ORDER BY o.poll_option_id"; $result = $db->sql_query($sql); $poll_info = $vote_counts = array(); while ($row = $db->sql_fetchrow($result)) { $poll_info[] = $row; $option_id = (int) $row['poll_option_id']; $vote_counts[$option_id] = (int) $row['poll_option_total']; } $db->sql_freeresult($result); $cur_voted_id = array(); if ($user->data['is_registered']) { $sql = 'SELECT poll_option_id FROM ' . POLL_VOTES_TABLE . ' WHERE topic_id = ' . $topic_id . ' AND vote_user_id = ' . $user->data['user_id']; $result = $db->sql_query($sql); while ($row = $db->sql_fetchrow($result)) { $cur_voted_id[] = $row['poll_option_id']; } $db->sql_freeresult($result); } else { // Cookie based guest tracking ... I don't like this but hum ho // it's oft requested. This relies on "nice" users who don't feel // the need to delete cookies to mess with results. if ($request->is_set($config['cookie_name'] . '_poll_' . $topic_id, \phpbb\request\request_interface::COOKIE)) { $cur_voted_id = explode(',', $request->variable($config['cookie_name'] . '_poll_' . $topic_id, '', true, \phpbb\request\request_interface::COOKIE)); $cur_voted_id = array_map('intval', $cur_voted_id); } } // Can not vote at all if no vote permission $s_can_vote = ($auth->acl_get('f_vote', $forum_id) && (($topic_data['poll_length'] != 0 && $topic_data['poll_start'] + $topic_data['poll_length'] > time()) || $topic_data['poll_length'] == 0) && $topic_data['topic_status'] != ITEM_LOCKED && $topic_data['forum_status'] != ITEM_LOCKED && (!count($cur_voted_id) || ($auth->acl_get('f_votechg', $forum_id) && $topic_data['poll_vote_change']))) ? true : false; $s_display_results = (!$s_can_vote || ($s_can_vote && count($cur_voted_id)) || $view == 'viewpoll') ? true : false; /** * Event to manipulate the poll data * * @event core.viewtopic_modify_poll_data * @var array cur_voted_id Array with options' IDs current user has voted for * @var int forum_id The topic's forum id * @var array poll_info Array with the poll information * @var bool s_can_vote Flag indicating if a user can vote * @var bool s_display_results Flag indicating if results or poll options should be displayed * @var int topic_id The id of the topic the user tries to access * @var array topic_data All the information from the topic and forum tables for this topic * @var string viewtopic_url URL to the topic page * @var array vote_counts Array with the vote counts for every poll option * @var array voted_id Array with updated options' IDs current user is voting for * @since 3.1.5-RC1 */ $vars = array( 'cur_voted_id', 'forum_id', 'poll_info', 's_can_vote', 's_display_results', 'topic_id', 'topic_data', 'viewtopic_url', 'vote_counts', 'voted_id', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_modify_poll_data', compact($vars))); if ($update && $s_can_vote) { if (!count($voted_id) || count($voted_id) > $topic_data['poll_max_options'] || in_array(VOTE_CONVERTED, $cur_voted_id) || !check_form_key('posting')) { $redirect_url = append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&t=$topic_id" . (($start == 0) ? '' : "&start=$start")); meta_refresh(5, $redirect_url); if (!count($voted_id)) { $message = 'NO_VOTE_OPTION'; } else if (count($voted_id) > $topic_data['poll_max_options']) { $message = 'TOO_MANY_VOTE_OPTIONS'; } else if (in_array(VOTE_CONVERTED, $cur_voted_id)) { $message = 'VOTE_CONVERTED'; } else { $message = 'FORM_INVALID'; } $message = $user->lang[$message] . '
' . sprintf($user->lang['RETURN_TOPIC'], '', ''); trigger_error($message); } foreach ($voted_id as $option) { if (in_array($option, $cur_voted_id)) { continue; } $sql = 'UPDATE ' . POLL_OPTIONS_TABLE . ' SET poll_option_total = poll_option_total + 1 WHERE poll_option_id = ' . (int) $option . ' AND topic_id = ' . (int) $topic_id; $db->sql_query($sql); $vote_counts[$option]++; if ($user->data['is_registered']) { $sql_ary = array( 'topic_id' => (int) $topic_id, 'poll_option_id' => (int) $option, 'vote_user_id' => (int) $user->data['user_id'], 'vote_user_ip' => (string) $user->ip, ); $sql = 'INSERT INTO ' . POLL_VOTES_TABLE . ' ' . $db->sql_build_array('INSERT', $sql_ary); $db->sql_query($sql); } } foreach ($cur_voted_id as $option) { if (!in_array($option, $voted_id)) { $sql = 'UPDATE ' . POLL_OPTIONS_TABLE . ' SET poll_option_total = poll_option_total - 1 WHERE poll_option_id = ' . (int) $option . ' AND topic_id = ' . (int) $topic_id; $db->sql_query($sql); $vote_counts[$option]--; if ($user->data['is_registered']) { $sql = 'DELETE FROM ' . POLL_VOTES_TABLE . ' WHERE topic_id = ' . (int) $topic_id . ' AND poll_option_id = ' . (int) $option . ' AND vote_user_id = ' . (int) $user->data['user_id']; $db->sql_query($sql); } } } if ($user->data['user_id'] == ANONYMOUS && !$user->data['is_bot']) { $user->set_cookie('poll_' . $topic_id, implode(',', $voted_id), time() + 31536000); } $sql = 'UPDATE ' . TOPICS_TABLE . ' SET poll_last_vote = ' . time() . " WHERE topic_id = $topic_id"; //, topic_last_post_time = ' . time() . " -- for bumping topics with new votes, ignore for now $db->sql_query($sql); $redirect_url = append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&t=$topic_id" . (($start == 0) ? '' : "&start=$start")); $message = $user->lang['VOTE_SUBMITTED'] . '
' . sprintf($user->lang['RETURN_TOPIC'], '', ''); if ($request->is_ajax()) { // Filter out invalid options $valid_user_votes = array_intersect(array_keys($vote_counts), $voted_id); $data = array( 'NO_VOTES' => $user->lang['NO_VOTES'], 'success' => true, 'user_votes' => array_flip($valid_user_votes), 'vote_counts' => $vote_counts, 'total_votes' => array_sum($vote_counts), 'can_vote' => !count($valid_user_votes) || ($auth->acl_get('f_votechg', $forum_id) && $topic_data['poll_vote_change']), ); /** * Event to manipulate the poll data sent by AJAX response * * @event core.viewtopic_modify_poll_ajax_data * @var array data JSON response data * @var array valid_user_votes Valid user votes * @var array vote_counts Vote counts * @var int forum_id Forum ID * @var array topic_data Topic data * @var array poll_info Array with the poll information * @since 3.2.4-RC1 */ $vars = array( 'data', 'valid_user_votes', 'vote_counts', 'forum_id', 'topic_data', 'poll_info', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_modify_poll_ajax_data', compact($vars))); $json_response = new \phpbb\json_response(); $json_response->send($data); } meta_refresh(5, $redirect_url); trigger_error($message); } $poll_total = 0; $poll_most = 0; foreach ($poll_info as $poll_option) { $poll_total += $poll_option['poll_option_total']; $poll_most = ($poll_option['poll_option_total'] >= $poll_most) ? $poll_option['poll_option_total'] : $poll_most; } $parse_flags = ($poll_info[0]['bbcode_bitfield'] ? OPTION_FLAG_BBCODE : 0) | OPTION_FLAG_SMILIES; for ($i = 0, $size = count($poll_info); $i < $size; $i++) { $poll_info[$i]['poll_option_text'] = generate_text_for_display($poll_info[$i]['poll_option_text'], $poll_info[$i]['bbcode_uid'], $poll_option['bbcode_bitfield'], $parse_flags, true); } $topic_data['poll_title'] = generate_text_for_display($topic_data['poll_title'], $poll_info[0]['bbcode_uid'], $poll_info[0]['bbcode_bitfield'], $parse_flags, true); $poll_template_data = $poll_options_template_data = array(); foreach ($poll_info as $poll_option) { $option_pct = ($poll_total > 0) ? $poll_option['poll_option_total'] / $poll_total : 0; $option_pct_txt = sprintf("%.1d%%", round($option_pct * 100)); $option_pct_rel = ($poll_most > 0) ? $poll_option['poll_option_total'] / $poll_most : 0; $option_pct_rel_txt = sprintf("%.1d%%", round($option_pct_rel * 100)); $option_most_votes = ($poll_option['poll_option_total'] > 0 && $poll_option['poll_option_total'] == $poll_most) ? true : false; $poll_options_template_data[] = array( 'POLL_OPTION_ID' => $poll_option['poll_option_id'], 'POLL_OPTION_CAPTION' => $poll_option['poll_option_text'], 'POLL_OPTION_RESULT' => $poll_option['poll_option_total'], 'POLL_OPTION_PERCENT' => $option_pct_txt, 'POLL_OPTION_PERCENT_REL' => $option_pct_rel_txt, 'POLL_OPTION_PCT' => round($option_pct * 100), 'POLL_OPTION_WIDTH' => round($option_pct * 250), 'POLL_OPTION_VOTED' => (in_array($poll_option['poll_option_id'], $cur_voted_id)) ? true : false, 'POLL_OPTION_MOST_VOTES' => $option_most_votes, ); } $poll_end = $topic_data['poll_length'] + $topic_data['poll_start']; $poll_template_data = array( 'POLL_QUESTION' => $topic_data['poll_title'], 'TOTAL_VOTES' => $poll_total, 'POLL_LEFT_CAP_IMG' => $user->img('poll_left'), 'POLL_RIGHT_CAP_IMG'=> $user->img('poll_right'), 'L_MAX_VOTES' => $user->lang('MAX_OPTIONS_SELECT', (int) $topic_data['poll_max_options']), 'L_POLL_LENGTH' => ($topic_data['poll_length']) ? sprintf($user->lang[($poll_end > time()) ? 'POLL_RUN_TILL' : 'POLL_ENDED_AT'], $user->format_date($poll_end)) : '', 'S_HAS_POLL' => true, 'S_CAN_VOTE' => $s_can_vote, 'S_DISPLAY_RESULTS' => $s_display_results, 'S_IS_MULTI_CHOICE' => ($topic_data['poll_max_options'] > 1) ? true : false, 'S_POLL_ACTION' => $viewtopic_url, 'U_VIEW_RESULTS' => $viewtopic_url . '&view=viewpoll', ); /** * Event to add/modify poll template data * * @event core.viewtopic_modify_poll_template_data * @var array cur_voted_id Array with options' IDs current user has voted for * @var int poll_end The poll end time * @var array poll_info Array with the poll information * @var array poll_options_template_data Array with the poll options template data * @var array poll_template_data Array with the common poll template data * @var int poll_total Total poll votes count * @var int poll_most Mostly voted option votes count * @var array topic_data All the information from the topic and forum tables for this topic * @var string viewtopic_url URL to the topic page * @var array vote_counts Array with the vote counts for every poll option * @var array voted_id Array with updated options' IDs current user is voting for * @since 3.1.5-RC1 */ $vars = array( 'cur_voted_id', 'poll_end', 'poll_info', 'poll_options_template_data', 'poll_template_data', 'poll_total', 'poll_most', 'topic_data', 'viewtopic_url', 'vote_counts', 'voted_id', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_modify_poll_template_data', compact($vars))); $template->assign_block_vars_array('poll_option', $poll_options_template_data); $template->assign_vars($poll_template_data); unset($poll_end, $poll_info, $poll_options_template_data, $poll_template_data, $voted_id); } // If the user is trying to reach the second half of the topic, fetch it starting from the end $store_reverse = false; $sql_limit = $config['posts_per_page']; $sql_sort_order = $direction = ''; if ($start > $total_posts / 2) { $store_reverse = true; // Select the sort order $direction = (($sort_dir == 'd') ? 'ASC' : 'DESC'); $sql_limit = $pagination->reverse_limit($start, $sql_limit, $total_posts); $sql_start = $pagination->reverse_start($start, $sql_limit, $total_posts); } else { // Select the sort order $direction = (($sort_dir == 'd') ? 'DESC' : 'ASC'); $sql_start = $start; } if (is_array($sort_by_sql[$sort_key])) { $sql_sort_order = implode(' ' . $direction . ', ', $sort_by_sql[$sort_key]) . ' ' . $direction; } else { $sql_sort_order = $sort_by_sql[$sort_key] . ' ' . $direction; } // Container for user details, only process once $post_list = $user_cache = $id_cache = $attachments = $attach_list = $rowset = $update_count = $post_edit_list = $post_delete_list = array(); $has_unapproved_attachments = $has_approved_attachments = $display_notice = false; $i = $i_total = 0; // Go ahead and pull all data for this topic $sql = 'SELECT p.post_id FROM ' . POSTS_TABLE . ' p' . (($join_user_sql[$sort_key]) ? ', ' . USERS_TABLE . ' u': '') . " WHERE p.topic_id = $topic_id AND " . $phpbb_content_visibility->get_visibility_sql('post', $forum_id, 'p.') . " " . (($join_user_sql[$sort_key]) ? 'AND u.user_id = p.poster_id': '') . " $limit_posts_time ORDER BY $sql_sort_order"; /** * Event to modify the SQL query that gets post_list * * @event core.viewtopic_modify_post_list_sql * @var string sql The SQL query to generate the post_list * @var int sql_limit The number of posts the query fetches * @var int sql_start The index the query starts to fetch from * @var string sort_key Key the posts are sorted by * @var string sort_days Display posts of previous x days * @var int forum_id Forum ID * @since 3.2.4-RC1 */ $vars = array( 'sql', 'sql_limit', 'sql_start', 'sort_key', 'sort_days', 'forum_id', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_modify_post_list_sql', compact($vars))); $result = $db->sql_query_limit($sql, $sql_limit, $sql_start); $i = ($store_reverse) ? $sql_limit - 1 : 0; while ($row = $db->sql_fetchrow($result)) { $post_list[$i] = (int) $row['post_id']; ($store_reverse) ? $i-- : $i++; } $db->sql_freeresult($result); if (!count($post_list)) { if ($sort_days) { trigger_error('NO_POSTS_TIME_FRAME'); } else { trigger_error('NO_TOPIC'); } } // Holding maximum post time for marking topic read // We need to grab it because we do reverse ordering sometimes $max_post_time = 0; $sql_ary = array( 'SELECT' => 'u.*, z.friend, z.foe, p.*', 'FROM' => array( USERS_TABLE => 'u', POSTS_TABLE => 'p', ), 'LEFT_JOIN' => array( array( 'FROM' => array(ZEBRA_TABLE => 'z'), 'ON' => 'z.user_id = ' . $user->data['user_id'] . ' AND z.zebra_id = p.poster_id', ), ), 'WHERE' => $db->sql_in_set('p.post_id', $post_list) . ' AND u.user_id = p.poster_id', ); /** * Event to modify the SQL query before the post and poster data is retrieved * * @event core.viewtopic_get_post_data * @var int forum_id Forum ID * @var int topic_id Topic ID * @var array topic_data Array with topic data * @var array post_list Array with post_ids we are going to retrieve * @var int sort_days Display posts of previous x days * @var string sort_key Key the posts are sorted by * @var string sort_dir Direction the posts are sorted by * @var int start Pagination information * @var array sql_ary The SQL array to get the data of posts and posters * @since 3.1.0-a1 * @changed 3.1.0-a2 Added vars forum_id, topic_id, topic_data, post_list, sort_days, sort_key, sort_dir, start */ $vars = array( 'forum_id', 'topic_id', 'topic_data', 'post_list', 'sort_days', 'sort_key', 'sort_dir', 'start', 'sql_ary', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_get_post_data', compact($vars))); $sql = $db->sql_build_query('SELECT', $sql_ary); $result = $db->sql_query($sql); $now = $user->create_datetime(); $now = phpbb_gmgetdate($now->getTimestamp() + $now->getOffset()); // Posts are stored in the $rowset array while $attach_list, $user_cache // and the global bbcode_bitfield are built while ($row = $db->sql_fetchrow($result)) { // Set max_post_time if ($row['post_time'] > $max_post_time) { $max_post_time = $row['post_time']; } $poster_id = (int) $row['poster_id']; // Does post have an attachment? If so, add it to the list if ($row['post_attachment'] && $config['allow_attachments']) { $attach_list[] = (int) $row['post_id']; if ($row['post_visibility'] == ITEM_UNAPPROVED || $row['post_visibility'] == ITEM_REAPPROVE) { $has_unapproved_attachments = true; } else if ($row['post_visibility'] == ITEM_APPROVED) { $has_approved_attachments = true; } } $rowset_data = array( 'hide_post' => (($row['foe'] || $row['post_visibility'] == ITEM_DELETED) && ($view != 'show' || $post_id != $row['post_id'])) ? true : false, 'post_id' => $row['post_id'], 'post_time' => $row['post_time'], 'user_id' => $row['user_id'], 'username' => $row['username'], 'user_colour' => $row['user_colour'], 'topic_id' => $row['topic_id'], 'forum_id' => $row['forum_id'], 'post_subject' => $row['post_subject'], 'post_edit_count' => $row['post_edit_count'], 'post_edit_time' => $row['post_edit_time'], 'post_edit_reason' => $row['post_edit_reason'], 'post_edit_user' => $row['post_edit_user'], 'post_edit_locked' => $row['post_edit_locked'], 'post_delete_time' => $row['post_delete_time'], 'post_delete_reason'=> $row['post_delete_reason'], 'post_delete_user' => $row['post_delete_user'], // Make sure the icon actually exists 'icon_id' => (isset($icons[$row['icon_id']]['img'], $icons[$row['icon_id']]['height'], $icons[$row['icon_id']]['width'])) ? $row['icon_id'] : 0, 'post_attachment' => $row['post_attachment'], 'post_visibility' => $row['post_visibility'], 'post_reported' => $row['post_reported'], 'post_username' => $row['post_username'], 'post_text' => $row['post_text'], 'bbcode_uid' => $row['bbcode_uid'], 'bbcode_bitfield' => $row['bbcode_bitfield'], 'enable_smilies' => $row['enable_smilies'], 'enable_sig' => $row['enable_sig'], 'friend' => $row['friend'], 'foe' => $row['foe'], ); /** * Modify the post rowset containing data to be displayed with posts * * @event core.viewtopic_post_rowset_data * @var array rowset_data Array with the rowset data for this post * @var array row Array with original user and post data * @since 3.1.0-a1 */ $vars = array('rowset_data', 'row'); extract($phpbb_dispatcher->trigger_event('core.viewtopic_post_rowset_data', compact($vars))); $rowset[$row['post_id']] = $rowset_data; // Cache various user specific data ... so we don't have to recompute // this each time the same user appears on this page if (!isset($user_cache[$poster_id])) { if ($poster_id == ANONYMOUS) { $user_cache_data = array( 'user_type' => USER_IGNORE, 'joined' => '', 'posts' => '', 'sig' => '', 'sig_bbcode_uid' => '', 'sig_bbcode_bitfield' => '', 'online' => false, 'avatar' => ($user->optionget('viewavatars')) ? phpbb_get_user_avatar($row) : '', 'rank_title' => '', 'rank_image' => '', 'rank_image_src' => '', 'pm' => '', 'email' => '', 'jabber' => '', 'search' => '', 'age' => '', 'username' => $row['username'], 'user_colour' => $row['user_colour'], 'contact_user' => '', 'warnings' => 0, 'allow_pm' => 0, ); /** * Modify the guest user's data displayed with the posts * * @event core.viewtopic_cache_guest_data * @var array user_cache_data Array with the user's data * @var int poster_id Poster's user id * @var array row Array with original user and post data * @since 3.1.0-a1 */ $vars = array('user_cache_data', 'poster_id', 'row'); extract($phpbb_dispatcher->trigger_event('core.viewtopic_cache_guest_data', compact($vars))); $user_cache[$poster_id] = $user_cache_data; $user_rank_data = phpbb_get_user_rank($row, false); $user_cache[$poster_id]['rank_title'] = $user_rank_data['title']; $user_cache[$poster_id]['rank_image'] = $user_rank_data['img']; $user_cache[$poster_id]['rank_image_src'] = $user_rank_data['img_src']; } else { $user_sig = ''; // We add the signature to every posters entry because enable_sig is post dependent if ($row['user_sig'] && $config['allow_sig'] && $user->optionget('viewsigs')) { $user_sig = $row['user_sig']; } $id_cache[] = $poster_id; $user_cache_data = array( 'user_type' => $row['user_type'], 'user_inactive_reason' => $row['user_inactive_reason'], 'joined' => $user->format_date($row['user_regdate']), 'posts' => $row['user_posts'], 'warnings' => (isset($row['user_warnings'])) ? $row['user_warnings'] : 0, 'sig' => $user_sig, 'sig_bbcode_uid' => (!empty($row['user_sig_bbcode_uid'])) ? $row['user_sig_bbcode_uid'] : '', 'sig_bbcode_bitfield' => (!empty($row['user_sig_bbcode_bitfield'])) ? $row['user_sig_bbcode_bitfield'] : '', 'viewonline' => $row['user_allow_viewonline'], 'allow_pm' => $row['user_allow_pm'], 'avatar' => ($user->optionget('viewavatars')) ? phpbb_get_user_avatar($row) : '', 'age' => '', 'rank_title' => '', 'rank_image' => '', 'rank_image_src' => '', 'username' => $row['username'], 'user_colour' => $row['user_colour'], 'contact_user' => $user->lang('CONTACT_USER', get_username_string('username', $poster_id, $row['username'], $row['user_colour'], $row['username'])), 'online' => false, 'jabber' => ($config['jab_enable'] && $row['user_jabber'] && $auth->acl_get('u_sendim')) ? append_sid("{$phpbb_root_path}memberlist.$phpEx", "mode=contact&action=jabber&u=$poster_id") : '', 'search' => ($config['load_search'] && $auth->acl_get('u_search')) ? append_sid("{$phpbb_root_path}search.$phpEx", "author_id=$poster_id&sr=posts") : '', 'author_full' => get_username_string('full', $poster_id, $row['username'], $row['user_colour']), 'author_colour' => get_username_string('colour', $poster_id, $row['username'], $row['user_colour']), 'author_username' => get_username_string('username', $poster_id, $row['username'], $row['user_colour']), 'author_profile' => get_username_string('profile', $poster_id, $row['username'], $row['user_colour']), ); /** * Modify the users' data displayed with their posts * * @event core.viewtopic_cache_user_data * @var array user_cache_data Array with the user's data * @var int poster_id Poster's user id * @var array row Array with original user and post data * @since 3.1.0-a1 */ $vars = array('user_cache_data', 'poster_id', 'row'); extract($phpbb_dispatcher->trigger_event('core.viewtopic_cache_user_data', compact($vars))); $user_cache[$poster_id] = $user_cache_data; $user_rank_data = phpbb_get_user_rank($row, $row['user_posts']); $user_cache[$poster_id]['rank_title'] = $user_rank_data['title']; $user_cache[$poster_id]['rank_image'] = $user_rank_data['img']; $user_cache[$poster_id]['rank_image_src'] = $user_rank_data['img_src']; if ((!empty($row['user_allow_viewemail']) && $auth->acl_get('u_sendemail')) || $auth->acl_get('a_email')) { $user_cache[$poster_id]['email'] = ($config['board_email_form'] && $config['email_enable']) ? append_sid("{$phpbb_root_path}memberlist.$phpEx", "mode=email&u=$poster_id") : (($config['board_hide_emails'] && !$auth->acl_get('a_email')) ? '' : 'mailto:' . $row['user_email']); } else { $user_cache[$poster_id]['email'] = ''; } if ($config['allow_birthdays'] && !empty($row['user_birthday'])) { list($bday_day, $bday_month, $bday_year) = array_map('intval', explode('-', $row['user_birthday'])); if ($bday_year) { $diff = $now['mon'] - $bday_month; if ($diff == 0) { $diff = ($now['mday'] - $bday_day < 0) ? 1 : 0; } else { $diff = ($diff < 0) ? 1 : 0; } $user_cache[$poster_id]['age'] = (int) ($now['year'] - $bday_year - $diff); } } } } } $db->sql_freeresult($result); // Load custom profile fields if ($config['load_cpf_viewtopic']) { /* @var $cp \phpbb\profilefields\manager */ $cp = $phpbb_container->get('profilefields.manager'); // Grab all profile fields from users in id cache for later use - similar to the poster cache $profile_fields_tmp = $cp->grab_profile_fields_data($id_cache); // filter out fields not to be displayed on viewtopic. Yes, it's a hack, but this shouldn't break any MODs. $profile_fields_cache = array(); foreach ($profile_fields_tmp as $profile_user_id => $profile_fields) { $profile_fields_cache[$profile_user_id] = array(); foreach ($profile_fields as $used_ident => $profile_field) { if ($profile_field['data']['field_show_on_vt']) { $profile_fields_cache[$profile_user_id][$used_ident] = $profile_field; } } } unset($profile_fields_tmp); } // Generate online information for user if ($config['load_onlinetrack'] && count($id_cache)) { $sql = 'SELECT session_user_id, MAX(session_time) as online_time, MIN(session_viewonline) AS viewonline FROM ' . SESSIONS_TABLE . ' WHERE ' . $db->sql_in_set('session_user_id', $id_cache) . ' GROUP BY session_user_id'; $result = $db->sql_query($sql); $update_time = $config['load_online_time'] * 60; while ($row = $db->sql_fetchrow($result)) { $user_cache[$row['session_user_id']]['online'] = (time() - $update_time < $row['online_time'] && (($row['viewonline']) || $auth->acl_get('u_viewonline'))) ? true : false; } $db->sql_freeresult($result); } unset($id_cache); // Pull attachment data if (count($attach_list)) { if ($auth->acl_get('u_download') && $auth->acl_get('f_download', $forum_id)) { $sql = 'SELECT * FROM ' . ATTACHMENTS_TABLE . ' WHERE ' . $db->sql_in_set('post_msg_id', $attach_list) . ' AND in_message = 0 ORDER BY attach_id DESC, post_msg_id ASC'; $result = $db->sql_query($sql); while ($row = $db->sql_fetchrow($result)) { $attachments[$row['post_msg_id']][] = $row; } $db->sql_freeresult($result); // No attachments exist, but post table thinks they do so go ahead and reset post_attach flags if (!count($attachments)) { $sql = 'UPDATE ' . POSTS_TABLE . ' SET post_attachment = 0 WHERE ' . $db->sql_in_set('post_id', $attach_list); $db->sql_query($sql); // We need to update the topic indicator too if the complete topic is now without an attachment if (count($rowset) != $total_posts) { // Not all posts are displayed so we query the db to find if there's any attachment for this topic $sql = 'SELECT a.post_msg_id as post_id FROM ' . ATTACHMENTS_TABLE . ' a, ' . POSTS_TABLE . " p WHERE p.topic_id = $topic_id AND p.post_visibility = " . ITEM_APPROVED . ' AND p.topic_id = a.topic_id'; $result = $db->sql_query_limit($sql, 1); $row = $db->sql_fetchrow($result); $db->sql_freeresult($result); if (!$row) { $sql = 'UPDATE ' . TOPICS_TABLE . " SET topic_attachment = 0 WHERE topic_id = $topic_id"; $db->sql_query($sql); } } else { $sql = 'UPDATE ' . TOPICS_TABLE . " SET topic_attachment = 0 WHERE topic_id = $topic_id"; $db->sql_query($sql); } } else if ($has_approved_attachments && !$topic_data['topic_attachment']) { // Topic has approved attachments but its flag is wrong $sql = 'UPDATE ' . TOPICS_TABLE . " SET topic_attachment = 1 WHERE topic_id = $topic_id"; $db->sql_query($sql); $topic_data['topic_attachment'] = 1; } else if ($has_unapproved_attachments && !$topic_data['topic_attachment']) { // Topic has only unapproved attachments but we have the right to see and download them $topic_data['topic_attachment'] = 1; } } else { $display_notice = true; } } if ($config['enable_accurate_pm_button']) { // Get the list of users who can receive private messages $can_receive_pm_list = $auth->acl_get_list(array_keys($user_cache), 'u_readpm'); $can_receive_pm_list = (empty($can_receive_pm_list) || !isset($can_receive_pm_list[0]['u_readpm'])) ? array() : $can_receive_pm_list[0]['u_readpm']; // Get the list of permanently banned users $permanently_banned_users = phpbb_get_banned_user_ids(array_keys($user_cache), false); } else { $can_receive_pm_list = array_keys($user_cache); $permanently_banned_users = []; } $i_total = count($rowset) - 1; $prev_post_id = ''; $template->assign_vars(array( 'S_HAS_ATTACHMENTS' => $topic_data['topic_attachment'], 'S_NUM_POSTS' => count($post_list)) ); /** * Event to modify the post, poster and attachment data before assigning the posts * * @event core.viewtopic_modify_post_data * @var int forum_id Forum ID * @var int topic_id Topic ID * @var array topic_data Array with topic data * @var array post_list Array with post_ids we are going to display * @var array rowset Array with post_id => post data * @var array user_cache Array with prepared user data * @var int start Pagination information * @var int sort_days Display posts of previous x days * @var string sort_key Key the posts are sorted by * @var string sort_dir Direction the posts are sorted by * @var bool display_notice Shall we display a notice instead of attachments * @var bool has_approved_attachments Does the topic have approved attachments * @var array attachments List of attachments post_id => array of attachments * @var array permanently_banned_users List of permanently banned users * @var array can_receive_pm_list Array with posters that can receive pms * @since 3.1.0-RC3 */ $vars = array( 'forum_id', 'topic_id', 'topic_data', 'post_list', 'rowset', 'user_cache', 'sort_days', 'sort_key', 'sort_dir', 'start', 'permanently_banned_users', 'can_receive_pm_list', 'display_notice', 'has_approved_attachments', 'attachments', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_modify_post_data', compact($vars))); // Output the posts $first_unread = $post_unread = false; for ($i = 0, $end = count($post_list); $i < $end; ++$i) { // A non-existing rowset only happens if there was no user present for the entered poster_id // This could be a broken posts table. if (!isset($rowset[$post_list[$i]])) { continue; } $row = $rowset[$post_list[$i]]; $poster_id = $row['user_id']; // End signature parsing, only if needed if ($user_cache[$poster_id]['sig'] && $row['enable_sig'] && empty($user_cache[$poster_id]['sig_parsed'])) { $parse_flags = ($user_cache[$poster_id]['sig_bbcode_bitfield'] ? OPTION_FLAG_BBCODE : 0) | OPTION_FLAG_SMILIES; $user_cache[$poster_id]['sig'] = generate_text_for_display($user_cache[$poster_id]['sig'], $user_cache[$poster_id]['sig_bbcode_uid'], $user_cache[$poster_id]['sig_bbcode_bitfield'], $parse_flags, true); $user_cache[$poster_id]['sig_parsed'] = true; } // Parse the message and subject $parse_flags = ($row['bbcode_bitfield'] ? OPTION_FLAG_BBCODE : 0) | OPTION_FLAG_SMILIES; $message = generate_text_for_display($row['post_text'], $row['bbcode_uid'], $row['bbcode_bitfield'], $parse_flags, true); if (!empty($attachments[$row['post_id']])) { parse_attachments($forum_id, $message, $attachments[$row['post_id']], $update_count); } // Replace naughty words such as farty pants $row['post_subject'] = censor_text($row['post_subject']); // Highlight active words (primarily for search) if ($highlight_match) { $message = preg_replace('#(?!<.*)(?]*(?:)#is', '\1', $message); $row['post_subject'] = preg_replace('#(?!<.*)(?]*(?:)#is', '\1', $row['post_subject']); } // Editing information if (($row['post_edit_count'] && $config['display_last_edited']) || $row['post_edit_reason']) { // Get usernames for all following posts if not already stored if (!count($post_edit_list) && ($row['post_edit_reason'] || ($row['post_edit_user'] && !isset($user_cache[$row['post_edit_user']])))) { // Remove all post_ids already parsed (we do not have to check them) $post_storage_list = (!$store_reverse) ? array_slice($post_list, $i) : array_slice(array_reverse($post_list), $i); $sql = 'SELECT DISTINCT u.user_id, u.username, u.user_colour FROM ' . POSTS_TABLE . ' p, ' . USERS_TABLE . ' u WHERE ' . $db->sql_in_set('p.post_id', $post_storage_list) . ' AND p.post_edit_count <> 0 AND p.post_edit_user <> 0 AND p.post_edit_user = u.user_id'; $result2 = $db->sql_query($sql); while ($user_edit_row = $db->sql_fetchrow($result2)) { $post_edit_list[$user_edit_row['user_id']] = $user_edit_row; } $db->sql_freeresult($result2); unset($post_storage_list); } if ($row['post_edit_reason']) { // User having edited the post also being the post author? if (!$row['post_edit_user'] || $row['post_edit_user'] == $poster_id) { $display_username = get_username_string('full', $poster_id, $row['username'], $row['user_colour'], $row['post_username']); } else { $display_username = get_username_string('full', $row['post_edit_user'], $post_edit_list[$row['post_edit_user']]['username'], $post_edit_list[$row['post_edit_user']]['user_colour']); } $l_edited_by = $user->lang('EDITED_TIMES_TOTAL', (int) $row['post_edit_count'], $display_username, $user->format_date($row['post_edit_time'], false, true)); } else { if ($row['post_edit_user'] && !isset($user_cache[$row['post_edit_user']])) { $user_cache[$row['post_edit_user']] = $post_edit_list[$row['post_edit_user']]; } // User having edited the post also being the post author? if (!$row['post_edit_user'] || $row['post_edit_user'] == $poster_id) { $display_username = get_username_string('full', $poster_id, $row['username'], $row['user_colour'], $row['post_username']); } else { $display_username = get_username_string('full', $row['post_edit_user'], $user_cache[$row['post_edit_user']]['username'], $user_cache[$row['post_edit_user']]['user_colour']); } $l_edited_by = $user->lang('EDITED_TIMES_TOTAL', (int) $row['post_edit_count'], $display_username, $user->format_date($row['post_edit_time'], false, true)); } } else { $l_edited_by = ''; } // Deleting information if ($row['post_visibility'] == ITEM_DELETED && $row['post_delete_user']) { // Get usernames for all following posts if not already stored if (!count($post_delete_list) && ($row['post_delete_reason'] || ($row['post_delete_user'] && !isset($user_cache[$row['post_delete_user']])))) { // Remove all post_ids already parsed (we do not have to check them) $post_storage_list = (!$store_reverse) ? array_slice($post_list, $i) : array_slice(array_reverse($post_list), $i); $sql = 'SELECT DISTINCT u.user_id, u.username, u.user_colour FROM ' . POSTS_TABLE . ' p, ' . USERS_TABLE . ' u WHERE ' . $db->sql_in_set('p.post_id', $post_storage_list) . ' AND p.post_delete_user <> 0 AND p.post_delete_user = u.user_id'; $result2 = $db->sql_query($sql); while ($user_delete_row = $db->sql_fetchrow($result2)) { $post_delete_list[$user_delete_row['user_id']] = $user_delete_row; } $db->sql_freeresult($result2); unset($post_storage_list); } if ($row['post_delete_user'] && !isset($user_cache[$row['post_delete_user']])) { $user_cache[$row['post_delete_user']] = $post_delete_list[$row['post_delete_user']]; } $display_postername = get_username_string('full', $poster_id, $row['username'], $row['user_colour'], $row['post_username']); // User having deleted the post also being the post author? if (!$row['post_delete_user'] || $row['post_delete_user'] == $poster_id) { $display_username = $display_postername; } else { $display_username = get_username_string('full', $row['post_delete_user'], $user_cache[$row['post_delete_user']]['username'], $user_cache[$row['post_delete_user']]['user_colour']); } if ($row['post_delete_reason']) { $l_deleted_message = $user->lang('POST_DELETED_BY_REASON', $display_postername, $display_username, $user->format_date($row['post_delete_time'], false, true), $row['post_delete_reason']); } else { $l_deleted_message = $user->lang('POST_DELETED_BY', $display_postername, $display_username, $user->format_date($row['post_delete_time'], false, true)); } $l_deleted_by = $user->lang('DELETED_INFORMATION', $display_username, $user->format_date($row['post_delete_time'], false, true)); } else { $l_deleted_by = $l_deleted_message = ''; } // Bump information if ($topic_data['topic_bumped'] && $row['post_id'] == $topic_data['topic_last_post_id'] && isset($user_cache[$topic_data['topic_bumper']]) ) { // It is safe to grab the username from the user cache array, we are at the last // post and only the topic poster and last poster are allowed to bump. // Admins and mods are bound to the above rules too... $l_bumped_by = sprintf($user->lang['BUMPED_BY'], $user_cache[$topic_data['topic_bumper']]['username'], $user->format_date($topic_data['topic_last_post_time'], false, true)); } else { $l_bumped_by = ''; } $cp_row = array(); // if ($config['load_cpf_viewtopic']) { $cp_row = (isset($profile_fields_cache[$poster_id])) ? $cp->generate_profile_fields_template_data($profile_fields_cache[$poster_id]) : array(); } $post_unread = (isset($topic_tracking_info[$topic_id]) && $row['post_time'] > $topic_tracking_info[$topic_id]) ? true : false; $s_first_unread = false; if (!$first_unread && $post_unread) { $s_first_unread = $first_unread = true; } $force_edit_allowed = $force_delete_allowed = $force_softdelete_allowed = false; $s_cannot_edit = !$auth->acl_get('f_edit', $forum_id) || $user->data['user_id'] != $poster_id; $s_cannot_edit_time = $config['edit_time'] && $row['post_time'] <= time() - ($config['edit_time'] * 60); $s_cannot_edit_locked = $topic_data['topic_status'] == ITEM_LOCKED || $row['post_edit_locked']; $s_cannot_delete = $user->data['user_id'] != $poster_id || ( !$auth->acl_get('f_delete', $forum_id) && (!$auth->acl_get('f_softdelete', $forum_id) || $row['post_visibility'] == ITEM_DELETED) ); $s_cannot_delete_lastpost = $topic_data['topic_last_post_id'] != $row['post_id']; $s_cannot_delete_time = $config['delete_time'] && $row['post_time'] <= time() - ($config['delete_time'] * 60); // we do not want to allow removal of the last post if a moderator locked it! $s_cannot_delete_locked = $topic_data['topic_status'] == ITEM_LOCKED || $row['post_edit_locked']; /** * This event allows you to modify the conditions for the "can edit post" and "can delete post" checks * * @event core.viewtopic_modify_post_action_conditions * @var array row Array with post data * @var array topic_data Array with topic data * @var bool force_edit_allowed Allow the user to edit the post (all permissions and conditions are ignored) * @var bool s_cannot_edit User can not edit the post because it's not his * @var bool s_cannot_edit_locked User can not edit the post because it's locked * @var bool s_cannot_edit_time User can not edit the post because edit_time has passed * @var bool force_delete_allowed Allow the user to delete the post (all permissions and conditions are ignored) * @var bool s_cannot_delete User can not delete the post because it's not his * @var bool s_cannot_delete_lastpost User can not delete the post because it's not the last post of the topic * @var bool s_cannot_delete_locked User can not delete the post because it's locked * @var bool s_cannot_delete_time User can not delete the post because edit_time has passed * @var bool force_softdelete_allowed Allow the user to —čoftdelete the post (all permissions and conditions are ignored) * @since 3.1.0-b4 * @changed 3.1.11-RC1 Added force_softdelete_allowed var */ $vars = array( 'row', 'topic_data', 'force_edit_allowed', 's_cannot_edit', 's_cannot_edit_locked', 's_cannot_edit_time', 'force_delete_allowed', 's_cannot_delete', 's_cannot_delete_lastpost', 's_cannot_delete_locked', 's_cannot_delete_time', 'force_softdelete_allowed', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_modify_post_action_conditions', compact($vars))); $edit_allowed = $force_edit_allowed || ($user->data['is_registered'] && ($auth->acl_get('m_edit', $forum_id) || ( !$s_cannot_edit && !$s_cannot_edit_time && !$s_cannot_edit_locked ))); $quote_allowed = $auth->acl_get('m_edit', $forum_id) || ($topic_data['topic_status'] != ITEM_LOCKED && ($user->data['user_id'] == ANONYMOUS || $auth->acl_get('f_reply', $forum_id)) ); // Only display the quote button if the post is quotable. Posts not approved are not quotable. $quote_allowed = ($quote_allowed && $row['post_visibility'] == ITEM_APPROVED) ? true : false; $delete_allowed = $force_delete_allowed || ($user->data['is_registered'] && ( ($auth->acl_get('m_delete', $forum_id) || ($auth->acl_get('m_softdelete', $forum_id) && $row['post_visibility'] != ITEM_DELETED)) || (!$s_cannot_delete && !$s_cannot_delete_lastpost && !$s_cannot_delete_time && !$s_cannot_delete_locked) )); $softdelete_allowed = $force_softdelete_allowed || (($auth->acl_get('m_softdelete', $forum_id) || ($auth->acl_get('f_softdelete', $forum_id) && $user->data['user_id'] == $poster_id)) && ($row['post_visibility'] != ITEM_DELETED)); $permanent_delete_allowed = $force_delete_allowed || ($auth->acl_get('m_delete', $forum_id) || ($auth->acl_get('f_delete', $forum_id) && $user->data['user_id'] == $poster_id)); // Can this user receive a Private Message? $can_receive_pm = ( // They must be a "normal" user $user_cache[$poster_id]['user_type'] != USER_IGNORE && // They must not be deactivated by the administrator ($user_cache[$poster_id]['user_type'] != USER_INACTIVE || $user_cache[$poster_id]['user_inactive_reason'] != INACTIVE_MANUAL) && // They must be able to read PMs in_array($poster_id, $can_receive_pm_list) && // They must not be permanently banned !in_array($poster_id, $permanently_banned_users) && // They must allow users to contact via PM (($auth->acl_gets('a_', 'm_') || $auth->acl_getf_global('m_')) || $user_cache[$poster_id]['allow_pm']) ); $u_pm = ''; if ($config['allow_privmsg'] && $auth->acl_get('u_sendpm') && $can_receive_pm) { $u_pm = append_sid("{$phpbb_root_path}ucp.$phpEx", 'i=pm&mode=compose&action=quotepost&p=' . $row['post_id']); } // $post_row = array( 'POST_AUTHOR_FULL' => ($poster_id != ANONYMOUS) ? $user_cache[$poster_id]['author_full'] : get_username_string('full', $poster_id, $row['username'], $row['user_colour'], $row['post_username']), 'POST_AUTHOR_COLOUR' => ($poster_id != ANONYMOUS) ? $user_cache[$poster_id]['author_colour'] : get_username_string('colour', $poster_id, $row['username'], $row['user_colour'], $row['post_username']), 'POST_AUTHOR' => ($poster_id != ANONYMOUS) ? $user_cache[$poster_id]['author_username'] : get_username_string('username', $poster_id, $row['username'], $row['user_colour'], $row['post_username']), 'U_POST_AUTHOR' => ($poster_id != ANONYMOUS) ? $user_cache[$poster_id]['author_profile'] : get_username_string('profile', $poster_id, $row['username'], $row['user_colour'], $row['post_username']), 'RANK_TITLE' => $user_cache[$poster_id]['rank_title'], 'RANK_IMG' => $user_cache[$poster_id]['rank_image'], 'RANK_IMG_SRC' => $user_cache[$poster_id]['rank_image_src'], 'POSTER_JOINED' => $user_cache[$poster_id]['joined'], 'POSTER_POSTS' => $user_cache[$poster_id]['posts'], 'POSTER_AVATAR' => $user_cache[$poster_id]['avatar'], 'POSTER_WARNINGS' => $auth->acl_get('m_warn') ? $user_cache[$poster_id]['warnings'] : '', 'POSTER_AGE' => $user_cache[$poster_id]['age'], 'CONTACT_USER' => $user_cache[$poster_id]['contact_user'], 'POST_DATE' => $user->format_date($row['post_time'], false, ($view == 'print') ? true : false), 'POST_DATE_RFC3339' => gmdate(DATE_RFC3339, $row['post_time']), 'POST_SUBJECT' => $row['post_subject'], 'MESSAGE' => $message, 'SIGNATURE' => ($row['enable_sig']) ? $user_cache[$poster_id]['sig'] : '', 'EDITED_MESSAGE' => $l_edited_by, 'EDIT_REASON' => $row['post_edit_reason'], 'DELETED_MESSAGE' => $l_deleted_by, 'DELETE_REASON' => $row['post_delete_reason'], 'BUMPED_MESSAGE' => $l_bumped_by, 'MINI_POST_IMG' => ($post_unread) ? $user->img('icon_post_target_unread', 'UNREAD_POST') : $user->img('icon_post_target', 'POST'), 'POST_ICON_IMG' => ($topic_data['enable_icons'] && !empty($row['icon_id'])) ? $icons[$row['icon_id']]['img'] : '', 'POST_ICON_IMG_WIDTH' => ($topic_data['enable_icons'] && !empty($row['icon_id'])) ? $icons[$row['icon_id']]['width'] : '', 'POST_ICON_IMG_HEIGHT' => ($topic_data['enable_icons'] && !empty($row['icon_id'])) ? $icons[$row['icon_id']]['height'] : '', 'POST_ICON_IMG_ALT' => ($topic_data['enable_icons'] && !empty($row['icon_id'])) ? $icons[$row['icon_id']]['alt'] : '', 'ONLINE_IMG' => ($poster_id == ANONYMOUS || !$config['load_onlinetrack']) ? '' : (($user_cache[$poster_id]['online']) ? $user->img('icon_user_online', 'ONLINE') : $user->img('icon_user_offline', 'OFFLINE')), 'S_ONLINE' => ($poster_id == ANONYMOUS || !$config['load_onlinetrack']) ? false : (($user_cache[$poster_id]['online']) ? true : false), 'U_EDIT' => ($edit_allowed) ? append_sid("{$phpbb_root_path}posting.$phpEx", "mode=edit&f=$forum_id&p={$row['post_id']}") : '', 'U_QUOTE' => ($quote_allowed) ? append_sid("{$phpbb_root_path}posting.$phpEx", "mode=quote&f=$forum_id&p={$row['post_id']}") : '', 'U_INFO' => ($auth->acl_get('m_info', $forum_id)) ? append_sid("{$phpbb_root_path}mcp.$phpEx", "i=main&mode=post_details&f=$forum_id&p=" . $row['post_id'], true, $user->session_id) : '', 'U_DELETE' => ($delete_allowed) ? append_sid("{$phpbb_root_path}posting.$phpEx", 'mode=' . (($softdelete_allowed) ? 'soft_delete' : 'delete') . "&f=$forum_id&p={$row['post_id']}") : '', 'U_SEARCH' => $user_cache[$poster_id]['search'], 'U_PM' => $u_pm, 'U_EMAIL' => $user_cache[$poster_id]['email'], 'U_JABBER' => $user_cache[$poster_id]['jabber'], 'U_APPROVE_ACTION' => append_sid("{$phpbb_root_path}mcp.$phpEx", "i=queue&p={$row['post_id']}&f=$forum_id&redirect=" . urlencode(str_replace('&', '&', $viewtopic_url . '&p=' . $row['post_id'] . '#p' . $row['post_id']))), 'U_REPORT' => ($auth->acl_get('f_report', $forum_id)) ? $phpbb_container->get('controller.helper')->route('phpbb_report_post_controller', array('id' => $row['post_id'])) : '', 'U_MCP_REPORT' => ($auth->acl_get('m_report', $forum_id)) ? append_sid("{$phpbb_root_path}mcp.$phpEx", 'i=reports&mode=report_details&f=' . $forum_id . '&p=' . $row['post_id'], true, $user->session_id) : '', 'U_MCP_APPROVE' => ($auth->acl_get('m_approve', $forum_id)) ? append_sid("{$phpbb_root_path}mcp.$phpEx", 'i=queue&mode=approve_details&f=' . $forum_id . '&p=' . $row['post_id'], true, $user->session_id) : '', 'U_MCP_RESTORE' => ($auth->acl_get('m_approve', $forum_id)) ? append_sid("{$phpbb_root_path}mcp.$phpEx", 'i=queue&mode=' . (($topic_data['topic_visibility'] != ITEM_DELETED) ? 'deleted_posts' : 'deleted_topics') . '&f=' . $forum_id . '&p=' . $row['post_id'], true, $user->session_id) : '', 'U_MINI_POST' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", 'p=' . $row['post_id']) . '#p' . $row['post_id'], 'U_NEXT_POST_ID' => ($i < $i_total && isset($rowset[$post_list[$i + 1]])) ? $rowset[$post_list[$i + 1]]['post_id'] : '', 'U_PREV_POST_ID' => $prev_post_id, 'U_NOTES' => ($auth->acl_getf_global('m_')) ? append_sid("{$phpbb_root_path}mcp.$phpEx", 'i=notes&mode=user_notes&u=' . $poster_id, true, $user->session_id) : '', 'U_WARN' => ($auth->acl_get('m_warn') && $poster_id != $user->data['user_id'] && $poster_id != ANONYMOUS) ? append_sid("{$phpbb_root_path}mcp.$phpEx", 'i=warn&mode=warn_post&f=' . $forum_id . '&p=' . $row['post_id'], true, $user->session_id) : '', 'POST_ID' => $row['post_id'], 'POST_NUMBER' => $i + $start + 1, 'POSTER_ID' => $poster_id, 'MINI_POST' => ($post_unread) ? $user->lang['UNREAD_POST'] : $user->lang['POST'], 'S_HAS_ATTACHMENTS' => (!empty($attachments[$row['post_id']])) ? true : false, 'S_MULTIPLE_ATTACHMENTS' => !empty($attachments[$row['post_id']]) && count($attachments[$row['post_id']]) > 1, 'S_POST_UNAPPROVED' => ($row['post_visibility'] == ITEM_UNAPPROVED || $row['post_visibility'] == ITEM_REAPPROVE) ? true : false, 'S_CAN_APPROVE' => $auth->acl_get('m_approve', $forum_id), 'S_POST_DELETED' => ($row['post_visibility'] == ITEM_DELETED) ? true : false, 'L_POST_DELETED_MESSAGE' => $l_deleted_message, 'S_POST_REPORTED' => ($row['post_reported'] && $auth->acl_get('m_report', $forum_id)) ? true : false, 'S_DISPLAY_NOTICE' => $display_notice && $row['post_attachment'], 'S_FRIEND' => ($row['friend']) ? true : false, 'S_UNREAD_POST' => $post_unread, 'S_FIRST_UNREAD' => $s_first_unread, 'S_CUSTOM_FIELDS' => (isset($cp_row['row']) && count($cp_row['row'])) ? true : false, 'S_TOPIC_POSTER' => ($topic_data['topic_poster'] == $poster_id) ? true : false, 'S_FIRST_POST' => ($topic_data['topic_first_post_id'] == $row['post_id']) ? true : false, 'S_IGNORE_POST' => ($row['foe']) ? true : false, 'L_IGNORE_POST' => ($row['foe']) ? sprintf($user->lang['POST_BY_FOE'], get_username_string('full', $poster_id, $row['username'], $row['user_colour'], $row['post_username'])) : '', 'S_POST_HIDDEN' => $row['hide_post'], 'L_POST_DISPLAY' => ($row['hide_post']) ? $user->lang('POST_DISPLAY', '', '') : '', 'S_DELETE_PERMANENT' => $permanent_delete_allowed, ); $user_poster_data = $user_cache[$poster_id]; $current_row_number = $i; /** * Modify the posts template block * * @event core.viewtopic_modify_post_row * @var int start Start item of this page * @var int current_row_number Number of the post on this page * @var int end Number of posts on this page * @var int total_posts Total posts count * @var int poster_id Post author id * @var array row Array with original post and user data * @var array cp_row Custom profile field data of the poster * @var array attachments List of attachments * @var array user_poster_data Poster's data from user cache * @var array post_row Template block array of the post * @var array topic_data Array with topic data * @var array user_cache Array with cached user data * @var array post_edit_list Array with post edited list * @since 3.1.0-a1 * @changed 3.1.0-a3 Added vars start, current_row_number, end, attachments * @changed 3.1.0-b3 Added topic_data array, total_posts * @changed 3.1.0-RC3 Added poster_id * @changed 3.2.2-RC1 Added user_cache and post_edit_list */ $vars = array( 'start', 'current_row_number', 'end', 'total_posts', 'poster_id', 'row', 'cp_row', 'attachments', 'user_poster_data', 'post_row', 'topic_data', 'user_cache', 'post_edit_list', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_modify_post_row', compact($vars))); $i = $current_row_number; if (isset($cp_row['row']) && count($cp_row['row'])) { $post_row = array_merge($post_row, $cp_row['row']); } // Dump vars into template $template->assign_block_vars('postrow', $post_row); $contact_fields = array( array( 'ID' => 'pm', 'NAME' => $user->lang['SEND_PRIVATE_MESSAGE'], 'U_CONTACT' => $post_row['U_PM'], ), array( 'ID' => 'email', 'NAME' => $user->lang['SEND_EMAIL'], 'U_CONTACT' => $user_cache[$poster_id]['email'], ), array( 'ID' => 'jabber', 'NAME' => $user->lang['JABBER'], 'U_CONTACT' => $user_cache[$poster_id]['jabber'], ), ); foreach ($contact_fields as $field) { if ($field['U_CONTACT']) { $template->assign_block_vars('postrow.contact', $field); } } if (!empty($cp_row['blockrow'])) { foreach ($cp_row['blockrow'] as $field_data) { $template->assign_block_vars('postrow.custom_fields', $field_data); if ($field_data['S_PROFILE_CONTACT']) { $template->assign_block_vars('postrow.contact', array( 'ID' => $field_data['PROFILE_FIELD_IDENT'], 'NAME' => $field_data['PROFILE_FIELD_NAME'], 'U_CONTACT' => $field_data['PROFILE_FIELD_CONTACT'], )); } } } // Display not already displayed Attachments for this post, we already parsed them. ;) if (!empty($attachments[$row['post_id']])) { foreach ($attachments[$row['post_id']] as $attachment) { $template->assign_block_vars('postrow.attachment', array( 'DISPLAY_ATTACHMENT' => $attachment) ); } } $current_row_number = $i; /** * Event after the post data has been assigned to the template * * @event core.viewtopic_post_row_after * @var int start Start item of this page * @var int current_row_number Number of the post on this page * @var int end Number of posts on this page * @var int total_posts Total posts count * @var array row Array with original post and user data * @var array cp_row Custom profile field data of the poster * @var array attachments List of attachments * @var array user_poster_data Poster's data from user cache * @var array post_row Template block array of the post * @var array topic_data Array with topic data * @since 3.1.0-a3 * @changed 3.1.0-b3 Added topic_data array, total_posts */ $vars = array( 'start', 'current_row_number', 'end', 'total_posts', 'row', 'cp_row', 'attachments', 'user_poster_data', 'post_row', 'topic_data', ); extract($phpbb_dispatcher->trigger_event('core.viewtopic_post_row_after', compact($vars))); $i = $current_row_number; $prev_post_id = $row['post_id']; unset($rowset[$post_list[$i]]); unset($attachments[$row['post_id']]); } unset($rowset, $user_cache); // Update topic view and if necessary attachment view counters ... but only for humans and if this is the first 'page view' if (isset($user->data['session_page']) && !$user->data['is_bot'] && (strpos($user->data['session_page'], '&t=' . $topic_id) === false || isset($user->data['session_created']))) { $sql = 'UPDATE ' . TOPICS_TABLE . ' SET topic_views = topic_views + 1, topic_last_view_time = ' . time() . " WHERE topic_id = $topic_id"; $db->sql_query($sql); // Update the attachment download counts if (count($update_count)) { $sql = 'UPDATE ' . ATTACHMENTS_TABLE . ' SET download_count = download_count + 1 WHERE ' . $db->sql_in_set('attach_id', array_unique($update_count)); $db->sql_query($sql); } } // Only mark topic if it's currently unread. Also make sure we do not set topic tracking back if earlier pages are viewed. if (isset($topic_tracking_info[$topic_id]) && $topic_data['topic_last_post_time'] > $topic_tracking_info[$topic_id] && $max_post_time > $topic_tracking_info[$topic_id]) { markread('topic', $forum_id, $topic_id, $max_post_time); // Update forum info $all_marked_read = update_forum_tracking_info($forum_id, $topic_data['forum_last_post_time'], (isset($topic_data['forum_mark_time'])) ? $topic_data['forum_mark_time'] : false, false); } else { $all_marked_read = true; } // If there are absolutely no more unread posts in this forum // and unread posts shown, we can safely show the #unread link if ($all_marked_read) { if ($post_unread) { $template->assign_vars(array( 'U_VIEW_UNREAD_POST' => '#unread', )); } else if (isset($topic_tracking_info[$topic_id]) && $topic_data['topic_last_post_time'] > $topic_tracking_info[$topic_id]) { $template->assign_vars(array( 'U_VIEW_UNREAD_POST' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&t=$topic_id&view=unread") . '#unread', )); } } else if (!$all_marked_read) { $last_page = ((floor($start / $config['posts_per_page']) + 1) == max(ceil($total_posts / $config['posts_per_page']), 1)) ? true : false; // What can happen is that we are at the last displayed page. If so, we also display the #unread link based in $post_unread if ($last_page && $post_unread) { $template->assign_vars(array( 'U_VIEW_UNREAD_POST' => '#unread', )); } else if (!$last_page) { $template->assign_vars(array( 'U_VIEW_UNREAD_POST' => append_sid("{$phpbb_root_path}viewtopic.$phpEx", "f=$forum_id&t=$topic_id&view=unread") . '#unread', )); } } // let's set up quick_reply $s_quick_reply = false; if ($user->data['is_registered'] && $config['allow_quick_reply'] && ($topic_data['forum_flags'] & FORUM_FLAG_QUICK_REPLY) && $auth->acl_get('f_reply', $forum_id)) { // Quick reply enabled forum $s_quick_reply = (($topic_data['forum_status'] == ITEM_UNLOCKED && $topic_data['topic_status'] == ITEM_UNLOCKED) || $auth->acl_get('m_edit', $forum_id)) ? true : false; } if ($s_can_vote || $s_quick_reply) { add_form_key('posting'); if ($s_quick_reply) { $s_attach_sig = $config['allow_sig'] && $user->optionget('attachsig') && $auth->acl_get('f_sigs', $forum_id) && $auth->acl_get('u_sig'); $s_smilies = $config['allow_smilies'] && $user->optionget('smilies') && $auth->acl_get('f_smilies', $forum_id); $s_bbcode = $config['allow_bbcode'] && $user->optionget('bbcode') && $auth->acl_get('f_bbcode', $forum_id); $s_notify = $config['allow_topic_notify'] && ($user->data['user_notify'] || $s_watching_topic['is_watching']); $qr_hidden_fields = array( 'topic_cur_post_id' => (int) $topic_data['topic_last_post_id'], 'topic_id' => (int) $topic_data['topic_id'], 'forum_id' => (int) $forum_id, ); // Originally we use checkboxes and check with isset(), so we only provide them if they would be checked (!$s_bbcode) ? $qr_hidden_fields['disable_bbcode'] = 1 : true; (!$s_smilies) ? $qr_hidden_fields['disable_smilies'] = 1 : true; (!$config['allow_post_links']) ? $qr_hidden_fields['disable_magic_url'] = 1 : true; ($s_attach_sig) ? $qr_hidden_fields['attach_sig'] = 1 : true; ($s_notify) ? $qr_hidden_fields['notify'] = 1 : true; ($topic_data['topic_status'] == ITEM_LOCKED) ? $qr_hidden_fields['lock_topic'] = 1 : true; $tpl_ary = [ 'S_QUICK_REPLY' => true, 'U_QR_ACTION' => append_sid("{$phpbb_root_path}posting.$phpEx", "mode=reply&f=$forum_id&t=$topic_id"), 'QR_HIDDEN_FIELDS' => build_hidden_fields($qr_hidden_fields), 'SUBJECT' => 'Re: ' . censor_text($topic_data['topic_title']), ]; /** * Event after the quick-reply has been setup * * @event core.viewtopic_modify_quick_reply_template_vars * @var array tpl_ary Array with template data * @var array topic_data Array with topic data * @since 3.2.9-RC1 */ $vars = ['tpl_ary', 'topic_data']; extract($phpbb_dispatcher->trigger_event('core.viewtopic_modify_quick_reply_template_vars', compact($vars))); $template->assign_vars($tpl_ary); } } // now I have the urge to wash my hands :( // We overwrite $_REQUEST['f'] if there is no forum specified // to be able to display the correct online list. // One downside is that the user currently viewing this topic/post is not taken into account. if (!$request->variable('f', 0)) { $request->overwrite('f', $forum_id); } // We need to do the same with the topic_id. See #53025. if (!$request->variable('t', 0) && !empty($topic_id)) { $request->overwrite('t', $topic_id); } $page_title = $topic_data['topic_title'] . ($start ? ' - ' . sprintf($user->lang['PAGE_TITLE_NUMBER'], $pagination->get_on_page($config['posts_per_page'], $start)) : ''); /** * You can use this event to modify the page title of the viewtopic page * * @event core.viewtopic_modify_page_title * @var string page_title Title of the viewtopic page * @var array topic_data Array with topic data * @var int forum_id Forum ID of the topic * @var int start Start offset used to calculate the page * @var array post_list Array with post_ids we are going to display * @since 3.1.0-a1 * @changed 3.1.0-RC4 Added post_list var */ $vars = array('page_title', 'topic_data', 'forum_id', 'start', 'post_list'); extract($phpbb_dispatcher->trigger_event('core.viewtopic_modify_page_title', compact($vars))); // Output the page page_header($page_title, true, $forum_id); $template->set_filenames(array( 'body' => ($view == 'print') ? 'viewtopic_print.html' : 'viewtopic_body.html') ); make_jumpbox(append_sid("{$phpbb_root_path}viewforum.$phpEx"), $forum_id); page_footer();
